Old 03-28-2012, 06:20 PM   #247
Overdrive
Opposed to Subie Burble
Overdrive's Avatar
i wonder if anyone has ever tied an electronic boost controller into a steering wheel position sensor - less boost when turning, more boost in the straights ...
But what happens if you happen to have the wheel in a neutral position in the middle of a turn/slide (not likely, but could happen)? Full boost when you don't necessarily want it. Or on the flip-side, your boost gets cut when you cut the wheel to move from behind someone to make a pass.
I definitely get where you're going with the idea and see potential with it, but that was where I could see trouble with such a thing.
-O/D
IMSR + RMS
Robbins glass window top
