Old 03-28-2012, 06:32 AM   #3
ppbon
ppbon's Avatar
Easy fix...
Originally Posted by Yorgos View Post
Hi guys, i'm Yorgos new member from Cyprus .I have problem with window on my boxster. i can't open/close full the window.. this problem happens to me for the second time, but be fine alone before .. can it be shifted? some ideas? thanks and sorry for my english (-:
video: boxster window problem - YouTube
Yorgos, the problem is in the soft top's latch microswitch.
Open the main top latch but leave the top closed.
With your finger press into the hole where the latch's hook goes into.
You'll hear two faint clicks from microswitches.
With the finger pressing these microswitches, operate your window.
It should go up all the way and when you release the pressure from your finger they will go back down a few centimeters.
If that's the case you need to adjust the travel of the microswitch.
Most of the time if you glue a piece of rubber (such as from an inner tube) 0.5 - 1.0 mm thick right on the tab where the latch's hook presses into that will be enough to engage the microswitch.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
