03-27-2012, 08:44 AM
#55
Originally Posted by Ghostrider 310
For the same reason you think doing preventative is a good investment. If you are going to keep the car are you really going to open it to that degree and pocket the grand a clutch kit costs? I wouldn't, at the very least I'd replace the slave cylinder and TO bearing, if the slave pees on the clutch plate one fine day, then you are reopening the case for a clutch you could have replaced.
My vehicle has 19k original miles, and so far as I can tell the clutch probably has 98.99% of life left in it . Why would I replace it at this point ? Should I also replace my toaster, microwave, DVD player, TV and any other appliance before it fails or wears out sometime in the next 15 to 20 years ?
