Old 03-25-2012, 08:29 PM   #2
nieuwhzn
nieuwhzn's Avatar
Hmmm… This kit connects to the fuel rail and you run your motor on the cleaner for just a couple minutes, it should not run on it for an hour. I question whether this cleaner breaks-down rubber, the hose on this kit is made of rubber and I have had this kit for 10 plus years and have not replaced it.
I doubt that running for a couple of minutes will clean much. Maybe the injector nozzles get a bit better, but TechRon in the tank will probably do the same with a lot less hassle.
nieuwhzn is offline   Reply With Quote
