Originally Posted by Kenny Boxster
Get the spark plugs and fuel filter replaced if you have not already done so. The spark plugs are a pain the the rear to get to and work on, but if you have the gumption you should be fine. Many people change all the filters in a car sans the fuel filter, so be sure to check it out after 100k miles.
FYI. The 987 does not have a fuel filter, that is maintainable. It's part of the pump, which is in the tank.
