Old 03-24-2012, 07:02 PM   #1
Jager
Jager's Avatar
Fuel Injector Cleaning
Has anyone used this type of system or similar to clean fuel injectors on their Boxster (see attached picture)? I use this system on my American built V8 motors and it does an excellent job. In fact I used this can to clean the injectors on my Tahoe this afternoon and it made a vast improvement on idle and throttle response. For those not familiar, basically you remove the fuse to the fuel pump and the motor runs on the can of cleaner. You have to regulate and monitor the pressure so you don’t dump the can of cleaner back into your fuel tank through the return line. I have not performed this type of fuel injector cleaning on my Boxster and would like to know if it’s doable using the test point, has anyone done this?
Jäger
300K Mile Club
