I have a recently completed E class Boxster that I need to sell QUIKLY to help fund my next project therefore the asking price of $22,500 OBO. I would like to sell it as a complete package, including my fully loaded 20' enclosed Haulmark, for $28,000. I inherited this car with a blown 3.4L motor and have since installed a very low mileage 2.7L and a bunch of other goodies.
The car is a very well cared for Black '99 that's been updated with a 2001 2.7L motor which puts it in PCA E class. Its equipped with the following:
Engine and Transmission:
New Gaurds LSD
New mass air sensor
New Oil Seperator 996 107 023 04
New Semi solid engine Mount
New Aasco Lightweight Aluminum Flywheel
New Sachs sport Clutch Kit
New Under Drive Pulley
New AC delete Muli-rib Belt 996 102 151 66
New LN Engineering IMS bearing
New Porsche updated RMS
New Factory X51 oil sump
New Shifter Cables
New Shifter Risers
New Porsche Coolant Expansion Tank 996 106 147 08
Short shift kit
3rd (center) radiator
K&N Air Filter
Suspension:
Bilstein PSS9 Kit
New front wheel bearings
New Eibach adjustable sway bars
New Tarret Front drop links
New Tarret Rear drop links
Alignment and Corner Balance
Brake System:
Pagid Brake Pads, Front
Pagid Brake Pads, Rear
Fresh SRF brake fluid
Safety:
Saftey Devices Full Roll Cage
Master Cut-off Switch
Fire Extinguisher
G Force 6 Point Harnesses with rotary buckle on driver and passanger side
Sparco Evo seats with Brey Krause sliders on both sides
Window Net
MOMO Steering with wheel hub adaptor and quik release
New Cool Suit System with 12 ft hose and dash mounted flow control
Longacre Wide Angle Mirror
Body:
Factory hardtop
Heat and AC removal
Lightweight Door Procedure
Rear Wing Modification
Hillman Locking Pin for Wing
Exhaust:
Custom FVD headers with cat delete and factory muffler
Spares:
1 full set of Boxster GT3 style wheels with good Toyo R888s mounted
2 ful set of Boxster GT3 style wheels with Hoosier R6s
1 extra set of Hoosier R6s
1 Spare Transmission
