Old 03-24-2012, 09:11 AM   #3
JFP in PA
Your post is the perfect case for why you should always find out the full definition for a code before you start swapping parts................
P1117 is the code for a problem with the heater circuit on the O2 sensor, but does not necessarily mean that the sensor needs to be changed; it could be a simple wiring or connector issue (very common), or it could be the sensor itself in the worst case scenario. That said, if it is a wiring issue, the new sensor will do the same thing.
Do some online research for the specific code (P1117) for the specific year of your car; you should find a full set of electrical circuit tests (voltage and continuity) that can be done with a $10 multi-meter before you jump (possibly without cause) for a much more expensive part that may or may not fix the problem............
