Old 03-23-2012, 11:05 AM   #1
tonycarreon
tonycarreon's Avatar
Originally Posted by cubbyno9 View Post
Tony my headlights are your first picture, bummer, the blackout film looks pretty good on your car mate. What do you mean sanding them down? Is it possible to take a very fine grinder/sanding disk and sand off the amber. Then when all amber off polish the lens???
when is say sand/paint i mean black them out. you won't be able to sand down the amber. it's all the plastic. on the newer ones, there's a film on the inside back of the turn signal that can be heated and removed. on the older ones (like you and i have) the plastic itself is amber.
as far as sanding/painting, there are a lot of youtube videos on how to do it, but essentially you:
1) fine grit sand the light so the paint has a surface to stick to
2) get some the tail light spray paint and paint them.
i believe you have to spray them a couple of times, let them dry and spray a clear coat on them afterwards. you'll then have black turn signals.
