Old 03-23-2012, 06:44 AM   #6
Bala
There are 3 components. One is the lower arm that connects to the wheel housing at the bottom. Then there is the control arm which is at the rear (sort of) and connects to the rear side bottom of the housing, 3rd is the track rod which is the loooong piece from the front of the wheel housing. You will see the terms used for the same parts at different vendors. Check the picture and the part number. Best way to ensure right part is ordered.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
