Old 03-17-2012, 09:37 PM   #1
silentfrosty
Herr Geschwindigkeit
Send a message via ICQ to silentfrosty
DIY 986 Motor Mount Replacement
I havn't been active at all here in the past, but hopefully that changes now that I am starting to fix my up Boxster. Besides basic maintenance, this is the second repair I've done myself (first was a water pump last year) and since I had some time, I decided to make a guide. Sorry if I go too in depth, this is my first guide, just trying to be thorough.
The car - '97 Boxster 2.5L / 150k Miles - Completely Stock
The Repair - Replacing front motor mount
Time it took me - 3 hours by myself
Difficulty - Easy (in my opinion)
Tools Needed - mm Wrench/Sockets, Jack/Jack stands, a vice came in handy
Part # used - 987-375-023-04
The background - About a year ago (long time to wait, I know) I noticed vibrations getting worse and worse, and eventually a loud grinding type noise whenever I made a left turn. I thought it was my bearings, and was about driving to my shop to replace them when my clutch goes out... Long story short, got the clutch replaced, and put the car up for the rest of the fall/winter, while I read up on the problem, figured it out and got the parts. Yesterday I got it in my shop and replaced the mount. Here is my step by step guide for replacing it.
First thing that I did was put it up on the lift, removed the one skid plate I have (long story, ran over a dead deer, I'll tell the story later if anyone is interested haha), then supported the engine with a jack + 2x8 (would of used a transmission jack if I had one).
There were 4 nuts on the carrier, and 3 bolts on the mount to take out (side by side pictures)
Middle View of carrier/mount
I'm doing this from memory, but I believe all 7 were 15mm. The nuts on the carrier were easy to get out, but once I went to take out the bolts from the mount, I realized I had to drop the engine down an inch or so (just for the two bolts on the bottom, the 3rd bolt on the top left of the mount just needs to be loosened)
After trying and failing, I eventually had to remove one of the radiator hoses to get the whole assembly out.
Once the hose was removed, the assembly came right out, you can see the rubber sticking out on the right side from this angle, looks bad right?
Take out the 2 bolts holding the mount to the carrier (15mm again I believe), I used a vice to hold it since it was pretty tight. This is when I realized just how bad it really was
A close up, you can see how bad it was wearing on the rubber
New mount attached to carrier
Install was pretty easy, just put the assembly in, and finger tighten the mount bolts, jack the engine back up, finger tighten the carrier nuts, torque the mount bolts, torque the carrier nuts, then re-attach the radiator hose.
All in all, it was a pretty easy install, the part that was most time consuming was draining/refilling/bleeding the coolant. After I was all done, took it for a drive, and it felt great.
There was still some vibration, but that's due to needing a front-end alignment which is getting done this coming week.
silentfrosty is offline   Reply With Quote
