					Originally Posted by Jittsl  May not apply to the Boxster. The GT3 had beastly powerful brakes and thus could generate the torque required to rotate the tires. Don't know if he Boxster could do so. Mark your tires (and wheels) and see if it does. If so, don't bother with balance.  If not, maybe worth it. |
If the tire beads are slipping on the wheel you can rough up the rim with a wire brush or course sandpaper & minimize mounting lube.
