Old 10-16-2005, 11:15 AM   #3
MNBoxster
Originally Posted by porschematt21
Sorry guys I was bit in a hurry. Alirght lowering the boxster with any lowing kit of any kinda i know its handles better right . But with the stiffness ruines the car ? I dont wanna be bouncing up and down the hole ride to school or something or taken the highway and being all over the place cause the springs and shocks. So would a lowing kit be for me ? I mean what was the result with ur guys lowing kits
Hi,
First off, why do you need it lowered? What's your goal? Unless you're Tracking or Auto-Xing the car, any performance benefit won't be used in Day-to-Day over the very good Stock Porsche Suspension. It's actually quite good Stock. I Auto-X my '99 on OEM suspension and it works quite well. IMHO, I don't think any potential improvement by lowering and adding Shocks will be worth the Time/Expense. This may be different for a Honda, but we're talking about Porsche here.
Lowering a Car is, admittedly, another form of Automotive Jewelry to many, so if that's your goal, by all means proceed.
Lowering a Car properly can yield some benefit. The key word here is properly. A Car's suspension is a complex, integrated system - change one thing and you affect the others, some positively, some negatively. Just slapping on some Springs is usually the wrong way to go about it. The Shocks/Struts need be considered as well. Can they cope with the increase in Spring Rate? Especially an increase in Rebound as opposed to Damping? And, your alignment needs to be adjusted for the changes. Usually lowering affects the wheels' Caster and the Rear will usually require less Camber to prevent additional Understeer. Set the Car up to Factory Specs and you can end up with a worse performing Car, increased Twitchiness, Tire Wear - Do Your Research! Lowering a Car wrong is just a waste of Time and Money.
So far as Ride Quality, this is very subjective. But, in general, Lowering a Car will increase the Ride's Harshness. Whether it will be too much for your (or your Passenger's) taste, only you can judge. Good Luck!
Happy Motoring!...Jim'99
