Old 03-14-2012, 01:14 AM   #11
shalco
Thanks for that, I hadn't considered the problem of the tighter inside radius on the curved plenum.
My car is an older 2.5 so was a cable throttle. I can confirm upgrading to a cable 996 3.4 TB is a big increase in power. I think this starts at 76mm & tapers down to maybe 74mm-ish at the butterfly.
I do have a previously fitted cable 80mm TB. This was an aftermarket ebay Nissan GTR TB. Its a good fit just needed oversized mounting holes, & an adapted bmw iacv plumbed in to the aos take off. It did from memory lack some torque below 4000 rpm compared to the 3.4 TB.
I think I may revisit this set up as I think its a shorter length compared to the 3.4 which means a less angled pipe could be connected.
shalco is offline   Reply With Quote
