Old 03-11-2012, 03:31 PM   #1
Brad Roberts
Brad Roberts's Avatar
FS: 01 BoxsterS engine $7500 (freshened)
Rebuilt heads with multi angle high perf valve job
Balanced rotating assembly with oiling mods to crank
All tolerances checked (crank/rods/crank carrier/P+C's)
LN IMS bearing
ALL new gaskets, all new seals, new chain guides, new chain tensioner pads for cams and IMS
Run tested for leaks
185 across the board on compression check
3% leak down across the board
Everything is spotless/cleaned prior to re-assembly
Dyno'd on stock tune at 270hp (more to be had with tuning/intake/exhaust changes)
1k install in southern CA.
We have engines IN STOCK. No waiting.
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
