Old 03-06-2012, 10:49 PM   #135
Renorush
Renorush's Avatar
I know this is an older thread, but I have a question. The original pics supplied by crios on 3/2/2009 show a muffler opened up showing the chambers inside. If a hole is drilled into the exhaust pipies coming out the back into the center chamber, it doesn't look like it would connect to where the exhaust gases would be coming out. The two pipes that come out the back appear to go to the left and right and the exhaust gets to them from the chambers to each side, not in the middle. So unless I'm missing something, drilling the holes as shown would only go into the middle section which has not exhaust gas connections with the other chambers. Is this correct?
Renorush is offline   Reply With Quote
