This is from the installation manual for the TPC supercharger
26. VERY IMPORTANT: Testing procedure for the additional injector controller.
a. Initial Test
i. With engine running, rev. engine to 2,200 rpm and rpm red light will come on.
ii. Blip throttle hard past 2,200 rpm and bst light (red) will come on.
iii. Blip throttle again and one or two (green) leds will illuminate to confirm your
injector is driving.
b. Final Test (to check if injector will fire)
i. Run engine at 2,200 rpm and disconnect trigger wire from injector (ground not
B+) and momentarily touch to ground to drive injector (Engine should flood
immediately).
ii. If engine does not flood. Push injector connector more firmly into place (wiggle
connector and push real damn hard).
27.DO NOT ATTEMPT TO TEST DRIVE CAR IF THE ABOVE PROCEDURE DOES NOT GO AS
OUTLINED.
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
