I've had 8 lifts in total. (owned an import shop for 8+ years.) 4 post, 2 post and scissor lifts. Even had a mid lift I got from an old Volvo dealer years ago.
The best by far, if your floor will support it is a 2 post lift. Either a Rotary or Bendpak. Best quality lifts I've ever bought. They just give you way more room to move around under as well as better access to the car your working on. If you do decide to get a 2 post make sure it's an open floor model. As the "hump" that is on the floor of the non open floor models make it a bugger to move a loaded jack stand over!
Even if your not sure on the floor and good contractor can come in a cut and pour in a good base into your existing floor.
Now there is a 2 post portable lift if you want to be able to move it. It's the MaxJax. It requires anchors to be put into your floor but it can be rolled out of the way after you use it. Great little lift. A buddy of mine has one at his home and loves it.
