Originally Posted by tonycarreon
as far as alignment i've only had it adjusted slightly at my local tire shop. nothing special required that i know of.
balance is another story. you want to make sure they do a road force balance, not just a regular balance and that they use the weights that are glued on, not tacked on to the rim. you'll never get it balanced right unless they do those two things - trust me.
So, the road force balance can only be done at the dealer? Or should I make sure Firestone has the equipment and does it?
For the alignment I though the camber needed to be done as well when suspension work is done? Or is that fixed? I did mark the eccentric washers so they will be going back in the same way but not sure how to confirm they are how they need to be. Thanks.
