Old 03-05-2012, 07:10 AM   #1
Bala
Originally Posted by tonycarreon View Post
as far as alignment i've only had it adjusted slightly at my local tire shop. nothing special required that i know of.
balance is another story. you want to make sure they do a road force balance, not just a regular balance and that they use the weights that are glued on, not tacked on to the rim. you'll never get it balanced right unless they do those two things - trust me.
So, the road force balance can only be done at the dealer? Or should I make sure Firestone has the equipment and does it?
For the alignment I though the camber needed to be done as well when suspension work is done? Or is that fixed? I did mark the eccentric washers so they will be going back in the same way but not sure how to confirm they are how they need to be. Thanks.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
