Old 03-04-2012, 01:40 PM   #23
anti-bling
STILL HAVE THE PROBLEM
Well, i looked at my suspension and saw that the right side was pretty well worn out (car was in a small accident and all suspension on right front was replaced with used parts)...they must have found a high mileage 986 to take from : /. So, i began the fixing. I replaced the wishbone and trac bar. New inner tie rod end is on its way as i noticed they didn't change the inner tie rod (its a little bent). Took strut out and tested it, its working great. Could the inner tie rod that be the sole problem? I don't know how it could as its not a spinning part, only controls turning. UGH...headache to say the least.
Don't reply telling me to contact the shop it was done at, trust me, i want nothing to do with them whatsoever.
ALSO- i put new rotors on the front recently (post shaking problem) and noticed it got worse. I looked at the rotors and noticed they don't line up perfectly (to the naked eye) to the hub. It seems the recessed, tapered, screw holes aren't perfect.
DOES ANYONE DO OR SELL HONEST WORK OR PARTS ANYMORE!?
anti-bling is offline   Reply With Quote
