TPC Supercharger question
I have recently purchased a 97 boxster with a TPC supercharger kit. Car is great but at rpms below 2K when you accelerate it seems to either get way to rich and miss or is way to lean. Has the same symptom when using lots of throttle. Check engine light flashes then when running smooths out it stops flashing. I suspect there may be a problem with extra injector controller. Does anyone have experience with this? Are any of the LED's on the control box supposed to illuminate on idle? It is installed in the trunk so impossible to see when driving.
Any help will be much appreciated.
Jim
