Old 03-02-2012, 05:37 AM   #1
Soetekouw
My Valentine is mounted on a clear acrylic bracket that is located between the headrest of the seats. The remote unit is on my steering column.
The bracket is an up-side-down Vee with a 90 degree projection at the bottom of each leg of the Vee that you can shove into the groove in the carpetting below the rear speaker/storage box where the front engine cover is. This holds the Vee bracket in place. On top of the point part of the Vee is a 90 degree projection where the Valentine sits on. I use a velcro strip to hold it in place.
Soetekouw is offline   Reply With Quote
