Originally Posted by onaFLYer
Update: I replaced the two hose that connect to TB, one from vent line, the other AOS hose. Both showed wear. It idles better when warm, but still throws the MAF code on a Snap-on scanner.
Just purchased a Durametric kit, hope to go for a drive to get some real data this weekend, if it stops snowing. Not much free time lately.
Just over 400 miles on it. Don't want to keep driving too much with evap system inop, might hurt the cats?
Assuming all your vacum leaks have been addressed..
Do you think it is the larger Cayman MAF housing causing the code? Are you running a special tune or the standard 3.2 one
You could try adapting a smaller (3" dia) but similar Bosh MAF housing. I can find the PNs if you like. You may have to cut or it may press in!! I will be facing the same issues if I use the 987 box.....Have yet to find one
Nice car by the way!
