Old 02-29-2012, 03:18 PM   #5
Daylorb
Originally Posted by milliemax View Post
The emergency "rip cord" for the front trunk is located on the passenger side inside the headlight area. Remove headlight pod and you will see it . Just extend it and re-rout it to the tow "plug" area. The cable moves from center to passenger side, so... drop the cable thru and around (to use as a pulley) the plastic bracket (black) and go back towards the center of the car. This makes it a easy to pull.
Nice - will try. I had read/seen it was on driver's side. Did they switch it at some point?
Daylorb is offline   Reply With Quote
