The emergency "rip cord" for the front trunk is located on the passenger side inside the headlight area. Remove headlight pod and you will see it . Just extend it and re-rout it to the tow "plug" area. The cable moves from center to passenger side, so... drop the cable thru and around (to use as a pulley) the plastic bracket (black) and go back towards the center of the car. This makes it a easy to pull.
