Thread: 1128 & 1130
Old 02-29-2012, 07:07 AM   #2
paulv
Terry,
Here's the info for P1128 & 1130:
Fault condition:
Fuel/air mixture so lean that sensing has reached its rich threshold.
Potential fault areas:
– Incorrect signal from MAF sensor
-- MAF is failing
– Intake air system leaking
-- Air is introduced past the MAF causing the mixture to be more lean
– Fuel pressure too low
-- Not enough fuel to meet demand causing the mixture to be more lean
– Volume supply of fuel pump too low
– Fuel injectors fouled
– Exhaust system leaking
-- When the exhaust system has leaks before the front O2 sensor will cause the O2 sensor to report a lean condition (excess oxygen i the exhaust)
BTW, I agree with Meir's recommendation. I have the Durametric tool and could have ruled out the MAF sensor in a couple of minutes (with the service info) -- with the key on and engine off, the MAF voltage should be approx 0.9 to 1.1 volts -- at idle, the voltage should be approx 1.4 volts.
Regards,
paul...
paulv is offline   Reply With Quote
