Old 02-28-2012, 11:25 AM   #19
truegearhead
truegearhead's Avatar
Originally Posted by ReallyDirtyThirty View Post
I really don't see what you're complaining about here, chief. I've known your cars for sometime and this one isn't any further off base than the others. For instance:
1999 Z3 Coupe- failed seat bracket bushings, window regulator required significant structural reinforcement, air vents get sucked out of the windows, hood cable which required the removal of the front end of the car, rear hatch rattles, strut bushings. You had that car for eight months.
1995 BMW 540/6: Head gasket, valve cover gaskets, $432 key replacement, head light ballasts that blew up, seat cables snapped and locked in position, OBC fan that sounded like a miniature weed wacker in the dash, door rust even though it lived inside, clutch slave, clutch master, idler pulley, glove box latches failed, steering box failure. You had that car for a year...
Should we talk about the E46 M3 or even the M52 swap car you had before that or have I been able to make my point??
The internet is a great place...right up to the point that you run into someone you know.
It's a little reassuring that some of you have experienced the same thing when you first purchased the car. Maybe I'm almost out of the woods. I will say that the car is very easy to work on, and yes far simpler then the M3 which was a complete nightmare. There were several jobs on that thing that took days to finish!
Cheers,
Stu
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
