Old 02-26-2012, 06:02 PM   #12
Steve Tinker
Steve Tinker's Avatar
Sorry, you are wrong..
The cage is there to only lightly retain the balls (the balls run in the so called "deep groove" of the bearing), and they dont come into contact because the lubricant (grease or oil film) acts as a buffer - the gap between the cage and balls is measured in microns.
The weight of the cage is measured in milligrams - the speeding up or slowing down would be insignificant unless your grease was so thick it caused drag.
2001 MV Agusta F4.
