Thanks guys.
Regarding the manual valve handle, I tried and tried to find a path to get it under the dash, but the only way I saw to do that was to drill a hole below the center console. If you do that, please post where you drill through - I might decide to try that some day.
Oh, by the way, I started the Accusump up for the first time today, and found I was making about 45 psi pressure at idle with warm oil (about 200 F water temp). This was way more than I expected at idle. I had one slight oil leak - it turns out the Canton guys had not installed the safety relief valve with any teflon tape, and had not tightened it very well.
Kippis
986S
991S
Van Diemen RF97
