Old 02-25-2012, 08:19 AM   #2
Gilles
Originally Posted by Bala View Post
took out both the axles. Wheel side boots were torn and grease was black dirt. Dipped both end in kerosene and cleaned everything to a shiny new metal. Many of the articles/posts talk about cleaning up the grease but none on total wash out. Am I doing a overkill?
Also on the tranny side I was able to take out the ball bearings during the cleaning process. It didn't just fall out but while some wiggling of the inner piece I was able to remove them. I cleaned out and put them back - needs a trick here. Should I replace the CV inner joint or am I good to go ahead repack with grease?
Bala,
The only way to properly inspect the bearing races (where the balls ride) for wear and scoring, is to completely disassemble the bearing.
It's like a small puzzle but IMHO this is the proper way to do it, once you clean and re-assemble the bearing, pack it up with grease and you should be good to go.
Gilles is offline   Reply With Quote
