Old 02-25-2012, 09:06 AM   #2
Gilles
Originally Posted by LAP1DOUG View Post
I was going to replace my control arm bushings as allowed by certain racing rules to minimize deflection that causes caster and toe change during wheel loading, but I can't figure out how in the world to remove the stock bushings.
I have hammered on them, and heated the control arms with a torch, but no still no luck. Does anyone know the trick to this?
Thanks for any info.
LAP1DOUG,
Your local alignment shop should have a small press that will make the job a lot easier, also I have seen some guys burning the rubber with a torch and then with a punch remove the metal ring.
However, if you having problems removing the old one, you may well be needing a press to install the new one
Remember, there is no substitute for the right tools...
