Boxster 986 Headlamp Adjustment
2003 Boxster Base
Passenger side headlamp is just fine. Driver side headlamp can't seem to get it adjust left or right correctly (using the upper adjustment for lateral movement and adjusting elevation with the bottom adjustment). The beam doesn't look crisp or defined, even after I replaced the bubs with the Silverstars.
It appears as if the driver side beam is being dispersed outwards, while the passenger side beam is will defined.
Any advice on this would be greatly appreciated!
