Axle boot replacement/maintenance
took out both the axles. Wheel side boots were torn and grease was black dirt. Dipped both end in kerosene and cleaned everything to a shiny new metal. Many of the articles/posts talk about cleaning up the grease but none on total wash out. Am I doing a overkill?
Also on the tranny side I was able to take out the ball bearings during the cleaning process. It didn't just fall out but while some wiggling of the inner piece I was able to remove them. I cleaned out and put them back - needs a trick here. Should I replace the CV inner joint or am I good to go ahead repack with grease?
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
