Old 02-24-2012, 02:45 PM   #1
harryrcb
Crazy Austrian
harryrcb's Avatar
Originally Posted by ed.w View Post
I also smell burning oil smell after parking my car. There has no leakage after check up at garage... And now I have my car color changed so sitting at the workshop for couple weeks seems no leakage.... Strange.
If you smell oil, then you are leaking it somewhere and burning it. could be so many different things some were already mentioned. I also have seen AOS tubes including the tubes from the heads to the AOS leak. on an older car they dry out and crack. Power steering pump reservoir could leak and the oil stays on top of engine until you drive and some spills and burns on the exhaust. Had a car that did that.
It's like smoke, you see it you smell it , there is a fire.
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
