The original mfg. of the IMS bearing was a NSK. The bearing # is 6204 2rs. Email tech support and ask them what is the recommeded lube would be for the bearing in the engine/conditions/temp and rpm of the bearing (1/2 max engine rpm), and how long that bearing will last in those conditions. You could also ask if the ceramic bearing would be better, S6204 2rs. It will take them a couple of days to get back to you.
