Old 10-11-2005, 08:13 AM   #5
mjw930
Originally Posted by bmussatti
Thanks Tommy986 and MJW930. I have seen those on E-bay. Will he make other colors? How long does it take to puy on? What keeps it from being stollen?
I think you can get custom colors and materials working with him directly. I have no idea on the lead time. With the ones he sells on ebay I got mine 3 days after the auction ended.
It's held on by velcro straps around the wipers and door handles as well as 3 tabs that go under the rear trunk cover. These tabs have a raised end that prevents them from being pulled out. I suppose, with enough force, they could be pulled out or simply cut off. If you are worried about the cover being stolen write your tag number on it in BIG letters with a Sharpie. It might make them think twice (probably not )
The reality is if they want it they will get it. If you have a metal gromet sewn in you could run a cable into the trunk. FWIW I would rather them take it vs. the type of damage they WILL do trying to remove it if it's cabled on.
mjw930 is offline   Reply With Quote
