Old 02-21-2012, 04:58 PM   #1
ferrytrip1
Have you thought about using an oval dash switch (similar to the type for Central Locking) and one of the empty dash switch locations on the left side of the center stack (where the PSM switch is located)? This would give you a completely stock look and use an existing stock Porsche switch.
That is exactly what I am trying to do - use an existing oval stock Porsche switch to give a stock look. I can place the switch either to the left of the PSM or in the center where the blanks are behind the ash tray ( I think this is where the heated seat switches so - I do not have heated seats)
My question is - which switch is suitable to do this? You suggest the Central locking. Is this an on / off or a rocker type? I thought it was a rocker type. For the DRL I want to use a switch that has an on position and an off position.
Thanks, Simon
ferrytrip1 is offline   Reply With Quote
