Originally Posted by Brad Roberts
This is the passenger side cam cover. A friend of mine in NorCal made an adapter for our data acq systems that included a VDO sending unit for oil temp and oil pressure. I can see if he has any of those adapters left over. His shop is in Milpitas.
![](http://986forum.com/forums/uploads01/Img_04381329790304.jpg)
Thanks Brad,
just to be sure: 996 driver's side = 986 passenger side
Do you mean the spot where the oil pressure switch goes? hmmmm that's where I have already my oil pressure sensor to feed my oil pressure gauge.
If that's the case then I'd need a T adapter to connect both the oil pressure sensor and the oil temp sensor ?
