Old 02-13-2012, 07:26 PM   #10
kcpaz
Originally Posted by Boxeer View Post
Glad to know you have the PS working with variable speed! I only heard people using it ON or OFF which is really bad for the pump to run 100% all the time.
When I look at the 2005 Boxster S engine on the floor. I have a hard time to imagine the axle the same length...
The only way it could be possible is if the engine is offset on the right a little bit. Or maybe It's a very good illusion. I just measured with approximation 6.5" in from input shaft of gearbox to left CV flange and only 5" from the same axis to the right CV flange.
Greg
Engine is not offset... I'm not sure what you are seeing but every Porsche I've been under uses equal length axles.
kcpaz is offline   Reply With Quote
