Originally Posted by MileHighBoxster
Oil expands when heated. Your reading will be lower cold than when hot, unless you are checking the two readings on two different grades/surfaces. Check it hot or cold but be consistent. Hot, it should show level somewhere just below full. Or, using the dip stick, just like every other car you've owned or driven.
From Rennlist: Check oil level with the engine off. Cold or hot. If cold be aware oil will expand maybe 1/2 quart's worth in volume. If hot be aware oil being hot has expanded and reading will be higher because of it.
My car's dipstick actually reads higher in the morning when the car is totally cold vs hot after the car has been sitting around for 2-3 hours. The e-gauge on the other hand, is more consistent. Showing "full" (1 mark below max) at both times.
I guess the oil takes longer to drain back to the sump - but that doesn't explain the e-gauge ??!!
Anyway the smokey starts are gone and as both show sufficient oil level, I'm just going to let it be.
