			Glad to know you have the PS working with variable speed! I only heard people using it ON or OFF which is really bad for the pump to run 100% all the time.
When I look at the 2005 Boxster S engine on the floor. I have a hard time to imagine the axle the same length...
The only way it could be possible is if the engine is offset on the right a little bit. Or maybe It's a very good illusion.  I just measured with approximation  6.5" in from input shaft of gearbox to left CV flange and only 5" from the same axis to the right CV flange.
Greg
