Old 02-13-2012, 09:30 AM   #2
The Radium King
The Radium King's Avatar
1) buy a brass plumbing fitting and use it as a buffer between your sledge and the axle; this way the brass will deform instead of your axle.
2) you can soak the cv in solvent to clean it, but inspect for damage caused by the grit. if you have to replace i recommend buying used as opposed to new oem (too expensive) or jobber (poor quality).
