Old 02-11-2012, 02:12 PM   #1
stateofidleness
"Converter Seal" or "Front pump seal"
Gents,
Dropped car off my indy the other day to investigate the leak I was having that I thought was the RMS. He emailed me back today saying:
"There is a bad trans fluid leak between the engine and transmission, I suspect either the converter seal or front pump seal."
Is this a normal failure item (MY'00 Tip) on these? I'm gonna assume this means removing trans, so should I have the IMS done at the same time?
stateofidleness is offline   Reply With Quote
