I have had the same problem and it is one of the easiest solutions you will find with these cars. You take the door panel off and you'll find that the spring that keeps the door handle from going "limp" is broken. It is an easy and cheap replacement. You're better off going with a Porsche Dealer for the part because it is a hard piece to find anywhere else from what I found and it isn't that expensive even from the dealer. I hope this helps.
