Limp door handle
Hey guys I was hoping someone encountered the same problem so I know what to look for and buy any parts before I pull the door apart. My problem is that my driver's side door handle is limp which causes the window to drop 1/4". When I push up on the handle the window closes so I know the switch is fine. Has anyone had the same problem? Is there a spring on the handle or the latch that keeps tension on the cable or could the cable just be worn out and stretched?
