Old 02-10-2012, 06:05 AM   #1
b55er
b55er's Avatar
Help - Tachometer Bad?
I had my 1998 986 sit in the garage for quite a while. Car has 25k on the clock.
Upon starting it up, and after temp reached 180°F, idle would sit around 1100.
Okay, I thought.. something is wrong. I take the car to the local Porsche dealer. Dealer says fuel trim levels are off and needs a new MAF. No codes no CEL. Dealer puts in a new MAF, resets all adaptations, etc, and sends me on my way; yet the car still idles at 1100. Dealer tells me that adaptations need to be set by driving about 60 miles. I take a nice 80 mile drive, car still idles around 1100. Back to the dealer.
I drop the car off at the dealer. Dealer hooks up car to their laptop, rechecks everything (fuel trim looks okay), takes off throttle body and says it's squeaky clean in there. No vacuum leaks. Dealer tells me that their computer states idle is at 850 and that engine management is working fine. Tech's ears also confirm 850.
Dealer now tells me there is nothing wrong with the car, and that the engine RPM sensor is working correctly as reported by the DME. Fault must lie in the tachometer.
Dealer tells me that nothing can be done to calibrate the tachometer. They suggest calling a VDO repair shop.
I call Palo Alto Speedometer (VDO) shop. They also tell me there is nothing that can be done to calibrate the instrument cluster. All other functions on the cluster work fine. Palo Alto Speedometer tells me to buy a used cluster (eBay?), and they'll flash my milage onto it (~$175).
Odd that the tach would be so much off. The instrument cluster has never been disassembled. With the car off, the tach needle rests in the same location as 3 other 986's that I observed at the dealership.
Any thoughts or ideas? Anyone seen this before?
Thanks..
B55er
b55er is online now   Reply With Quote
