Old 02-10-2012, 03:30 AM   #14
Bala
What a pain these bolts are. Maybe its just my car. Spent 6 hours removing the wishbone, sway bar, drop link bolts. Propane torch speeded up the things. Still broke the abs sensor ones and need to deal with it. Aso remaining are the bolts over the wheel bearing housing.
Both wheel bearings seemed fine when checked with the wheel on but when all was reoved there is some play. Recommend folks taking out the wheel assembly to check. "Better to do it while you are in there".
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
