Old 02-09-2012, 08:40 PM   #18
Kroggers
Originally Posted by LAP1DOUG View Post
No doubt - in the middle of the Summer if your engine is at normal operating temperature, and you sit for several minutes with no airflow, your engine is liable to start puking water / water wetter.
However, if you plan ahead, and get the engine just a bit warm and shut it off when you first get to grid, you will be OK. Then just start it up again when you get the 1 minute warning.
Good luck.
Or I could go half-way and just remove one fan - maybe as has already been suggested, to remove the one on the driver side only?
Kroggers...
"Trying to drive a Boxster S for team CoolCava Racing!"
www.coolcavaracing.com | www.paulkrogdahl.com
Kroggers is offline   Reply With Quote
