Originally Posted by Kroggers
That is something to consider - once you have started the car, driven slowly threw from the paddock to the grid and been siting there for several minutes with the engine running. Will it start to over heat if there is no fans there?
No doubt - in the middle of the Summer if your engine is at normal operating temperature, and you sit for several minutes with no airflow, your engine is liable to start puking water / water wetter.
However, if you plan ahead, and get the engine just a bit warm and shut it off when you first get to grid, you will be OK. Then just start it up again when you get the 1 minute warning.
Good luck.
